Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
lowering blazer cheap??
Old Jun 18, 2009 | 12:01 PM
mr.hotrod's Avatar
mr.hotrod is on a distinguished road
Default lowering blazer cheap??
Hey does anyone know how to lower a chevy blazer on the cheap? my giant sub takes care of the back but my front is way too high
Old Jun 18, 2009 | 12:47 PM
oktain's Avatar
It's a 4x4 right? Why would you want to lower it?
In any case I know one guy who cut his coil springs in the front with a plasma cutter... I've heard of torching the front coil springs (weakening them, I personally wouldn't try) but both these methods are free.
I'm not really the guy to be answering this question but I'm sure packofqtips could point you in the right direction.
Do some searching through the forum too.
Old Jun 18, 2009 | 01:32 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
4x4 or 2wd?
2wd lowering springs are very cheap
4x4 can crank the torsion bars down for a 2 inch drop
Old Jun 18, 2009 | 04:04 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
and if you dont know how to crank your tbars just look up the DIY on how to crank tbars and just do the opposite and if your lucky you might even get 3" of drop from the tbars.
Old Jun 18, 2009 | 06:37 PM
Sisk's Avatar
I wouldn't recommend cutting the springs...its pretty sketchy.
Old Jul 4, 2009 | 12:20 AM
transformer's Avatar
transformer is on a distinguished road
Default get low
depends on ride height and which blazer
I got a 99 w/ a 3-4 drop with springs, spindles, & blocks
had to do some adjusting (cut bump stops)
camber/caster
but it will eat ball joints quicker and tie rod ends unless you spend more $$$
flip the rear break hoses (or youll eat holes in them)
also watch out for lock to lock turns... it might pose a breaking problem in parking lots with the front breaks
pretty good sticky at blazinlow forum... search it
Old Jul 4, 2009 | 11:04 PM
mr.hotrod's Avatar
yea its my 92 4x4 and im sorry but nothin is more anoying than having a lifted truck in indiana. its flat out here!. i just like lowriders better
Old Jul 7, 2009 | 07:05 PM
turtlehumper2000's Avatar
turtlehumper2000 is on a distinguished road
Crank your t bars down and im pretty sure you can use the rear drop from a 2wd kit ($150 from 4 Wheel Parts) Someone correct me if im wrong.
Rumblur
Lowering Tech
Jun 1, 2013 09:02 AM
igot10pinitis
Lowering Tech
Sep 23, 2007 07:57 PM
AdamM
Headers, Intake, & Exhaust
Aug 23, 2007 03:22 PM
lennyblazer
May 26, 2007 07:08 AM
Headcas3
Suspension Tech
Jul 26, 2005 10:29 PM
