Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
SWAY BAR LINKS
Old Nov 25, 2007 | 05:44 PM
phins54's Avatar
phins54 is an unknown quantity at this point
Default SWAY BAR LINKS
I LOWERD MY 2002 S-10 BLAZER 2WDBY 3INCH SHOULD I CHANGED THE SWAY BAR LINKS
TO SHORTER ONE OR DOES IT MATTER IF I DONT
THANK YOU [8D]
Old Nov 25, 2007 | 09:23 PM
Default RE: SWAY BAR LINKS
*Moving to Lowering Tech*
How bad do the old ones look, angle wise? Does it look like they are binding? If it does, then replace them with shorter versions (if available).
Old Nov 26, 2007 | 05:48 AM
thegr81's Avatar
Unless its creating a binding issue like swartllkk said I wouldn't worry about it at all! When you lowered your front end did you use drop spindles and springs? If you did those in conjunction with each other maintain factory geometry!!
blazerJim1701
Oct 21, 2010 05:30 AM
blzrls
Apr 7, 2009 04:13 AM
MeidleinA
Apr 15, 2008 11:06 PM
95BlazerLt4wd
Lifting Tech
Mar 4, 2008 08:58 PM
samurai_24
Sep 26, 2007 09:22 AM
