93 Blazer Gauges go Wacky!
Old Aug 28, 2012 | 12:49 PM
allan_bob's Avatar
allan_bob is on a distinguished road
Default 93 Blazer Gauges go Wacky!
Has anyone else had a similar problem? When the key is turn on all the gauges bounce for around 10 seconds before settling down.
Old Aug 28, 2012 | 02:09 PM
Rottidog's Avatar
1st off I'd say ignition switch.
2nd you'll probably find the answer or similiar issues others have had if you use the Search feature at the top.
Old Sep 4, 2012 | 05:10 PM
Jeff Hoard's Avatar
Jeff Hoard is on a distinguished road
does it crank hard because mine use to do that and then shortly after battery went out, if ur battery isnt holding voltage after u shut it off it would cause low voltage. and that could mess up ur guages soo idk its worth a try try using a multimeter on ur battery next time before u start it if its under 11 volts its prob ur battery
Old Sep 5, 2012 | 10:56 AM
allan_bob's Avatar
So far we have replaced the alternator, battery and the complete steering column. The gauges still bounce when the key is turned on.
Old Sep 5, 2012 | 03:46 PM
FsTFwRd's Avatar
My gas gauge will bounce around. But it hasn't worked in 3 years. You say it only does this for the first ten seconds of the ignition switch in the on position?
Old Sep 6, 2012 | 07:21 AM
allan_bob's Avatar
Could the ecm be going bad?
Old Oct 13, 2012 | 11:39 PM
DKSDAD's Avatar
Welcome from New York.
Brian5792
Jan 16, 2013 10:02 AM
AuSSenseiter
Nov 16, 2011 05:17 PM
Gilmore1313
Oct 10, 2010 04:27 PM
MIKE12657
Sep 23, 2009 08:34 PM
mightymo61
Mar 19, 2009 02:34 PM
