Brake Failure - Rough Idle
Old May 24, 2012 | 03:10 PM
cricketkoger's Avatar
cricketkoger is on a distinguished road
Default Brake Failure - Rough Idle
Having an intermittent rough idle that sometimes completely stalls. Each time rough idle starts I lose power brakes (not just when stalled) If I remove the Brake Booster Vac line...Engine runs smoothly...Any tips???
Old May 24, 2012 | 03:17 PM
rexmburns's Avatar
Super Moderator
Welcome to the forum. You will have better luck if you post your questions in the appropriate sections as stated in the forum rules.
Old May 24, 2012 | 03:38 PM
Thogert's Avatar
^x2 and welcome from Utah.
Old May 24, 2012 | 05:28 PM
Default oops...
Thank You rexmburns...Typical newbie...I pushed buttons before reading instructions Thanks for taking the time to let me know
Old May 29, 2012 | 01:31 PM
rexmburns's Avatar
Super Moderator
Haha no worries that's what we are all here for is to help each other out!
Old May 29, 2012 | 01:53 PM
xgiovannix12's Avatar
welcome from NY ...
It sounds like the Large vac line came off your brake booster
Old May 29, 2012 | 11:11 PM
gojorg's Avatar
Welcome from New Jersey
Old May 30, 2012 | 04:13 PM
Ogre762's Avatar
Ogre762 is on a distinguished road
Welcome!
Does it only happen randomly? You might have a bad booster and it's creating a vacuum leak.
Old Jun 12, 2012 | 03:42 PM
dagda's Avatar
dagda is on a distinguished road
Do you hear a hissing sound from within the dash when you press the brakes? A hissing could indicate a bad booster, otherwise it sounds like you have a leak at the vacuum line under the hood going to the booster. There is also the possibility of a failure at the check valve where the vacuum line connects to the booster. I would also check your brake fluid level. A leak in your master cylinder can cause the diaphragm to fail inside the booster.
Old Jun 12, 2012 | 09:48 PM
Rottidog's Avatar
It also helps a LOT to know what year, make, model etc. Most have that info in their sigs.
How are the HVAC controls? When you switch it to defrost can you still feel air being blown through a vent or to the floor? If so then you for sure have a vacuum leak. Like everyone has said there seems to be a vacuum leak somewhere & finding it, replacing the offending line should sure that issue. Or like Ogre said it may be a bad booster. Check out the vacuum lines 1st. Run the engine & spray brake cleaner over the lines. If the idle changes, VOILA you've found a leaky line. Cracked tee's are another issue when they get old.
