my 2000 blazer s10
Old Feb 5, 2009 | 01:19 PM
keithduke65's Avatar
keithduke65 is an unknown quantity at this point
Default my 2000 blazer s10
just bought my 2000 blazer this past xmas, i could not believe how the previous owner let this rig go so bad. i paid 1700 dollars for it only because the blazer was in mint condition inside and out . ill start from the beginning and list everthing. 1 heater core leaking
/fixed it with radiator stop leak.2abs light on ,found wire off at one of the wheels,3door pins both doors,4gas tank leaking, took gas tank down return line was not even attached,replaced all lines5spare tire on back rack was bald when i took cover off.6headlights practically falling out7engine light came on found the motor was misfiring changed spark plugs ,they had three different types of spark plugs ngk ac and one i cant even pronounce.8front lovre under bumper missing bought and painted new one for around75 dollars9lever for hood busted simply put small clamp on cable10 when you put it in 4x4 it would make clunking noise every 10 feet or so,i thought the transfer case was done until the blower for the heater would only work through the front vents after some pickingat the problem i found that the blower cruise and the trasfer switch all worked off air after looking over the hoses found the main hose coming from the motor was pinched and when i tried to take it off it broke .reconnected the new hose now 4x4 is smooth and blower working properly.last the alternator gave out. oh yeah there was no handbreak . i took off the back wheels to discover there not even any shoes there . for about a 100 dollars for the kit and shoes they were easy to install. by the way im an electrician.
94BlazerGirl
Aug 28, 2014 06:14 PM
01Blaze218
Oct 13, 2011 10:05 AM
rfine67
Aug 13, 2011 01:04 PM
cc4usa
Oct 31, 2009 09:22 PM
rob2129us
Dec 7, 2007 11:09 AM
