Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
N20 on a 4wd Blazer?
Old Feb 15, 2007 | 01:31 AM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default N20 on a 4wd Blazer?
I have a 2000 4wd Blazer. I want Nitrous Oxide. I just want to know if it's okay to use on a 4wd vehicle or not. What are your thoughts? If it's not a good idea, I am thinking of buying a 2004ish Xtreme to put a turbo and NOS in, and giving my 2000 Blazer to my younger brother.
Old Feb 20, 2007 | 05:33 AM
BLK85's Avatar
BLK85 is an unknown quantity at this point
Default RE: N20 on a 4wd Blazer?
You can use it on anything you want.
Old Feb 20, 2007 | 06:07 AM
KLBlazer07's Avatar
KLBlazer07 is an unknown quantity at this point
ORIGINAL: BLK85
How about my lawn mower?
Old Feb 20, 2007 | 06:23 AM
drperry's Avatar
ORIGINAL: KLBlazer07
ORIGINAL: BLK85
It's been done before... As well as turbo lawn mowers... Mower races are funny to watch, lol
Old Feb 20, 2007 | 10:48 AM
I mean are the 4wd gears in the rear differential too sensitive to install nos?
Old Feb 20, 2007 | 11:02 AM
drperry's Avatar
They're the same gears as the 2wd version...
With the exception of the ZR2, which, if I remember right, gets a beefier rear end...
Old Mar 13, 2007 | 11:27 PM
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
i ran a 100shot on my bone stock 2wd 2door blazer for a WHILE!..... if you have 4wd you should have an 8.5" 10-bolt which is stronger then a 7.5" 10-bolt. it should be fine.
Old Mar 14, 2007 | 08:30 AM
drperry's Avatar
Only the ZR2's got the 8.5" rear end, all other Blazers have the 7 5/8"
Both are 10 bolt.
Old Mar 14, 2007 | 10:50 AM
BLK85's Avatar
You'll be fine. A 100 shot would only get you tow 290 fly wheel hp, which is not much. My buddies usually didnt break their stock 10 bolts in ther F-bodies until they got to about 400 rwhp. Although who knows you could break stuff, anytime you start adding hp there are eno gaurantees.
Old Jun 16, 2007 | 01:36 AM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
not to hijack your thread, but how do you plan on bumping the timing back and richening the mixture?
