Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
N20 on a 4wd Blazer?
Old Jun 22, 2007 | 06:52 PM
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
Default RE: N20 on a 4wd Blazer?
hptuners, EFIlive, ls1edit
BTw- you can make all the power you need with one power adder or the other... IMO its stupid to run turbo and NITROUS (not NOS). i have run both seperatly. The only reason i would run nitrous with boost is to help on the topend. A 25shot from 4krpm on up to help the topend that these trucks so dearly lack...... its easy to max out the stock bottom end with boost....
also it isnt HP that kills transmissions and rearends, its weight and torque, both which we have alot of. so we will break them if anything sooner then an f-body unless the f-body is a 6-speed car and hes dropping the clutch nasty style. i will be swapping to a ford 8.8" soon enough.
Old Sep 16, 2007 | 11:04 AM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
I'm also curious about this, I have a 4wd Jimmy, completely stock. If I were to put a sneeky pete system, should I drop the stock airbox/intake for a coldair intake before installing it? Any benefit to this? My truck having the MFI update, will it perform better?
Geir
Oct 9, 2011 08:51 PM
ttwo
Oct 28, 2010 12:35 PM
2001 ZR2
Jan 16, 2010 12:39 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
