Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
Supercharger prep
Old Mar 30, 2008 | 09:04 PM
blazerbeam's Avatar
blazerbeam is an unknown quantity at this point
Default Supercharger prep
so looking at a supercharger install down the line... wondering what kind of work will have to go into the motor.
i know the stock motor can handle around 6psi but if i'm going to rebuild the motor, i might as well put a little bit into it just to help it out.
any suggestions?
Old Apr 4, 2008 | 08:15 AM
UR50SLO's Avatar
UR50SLO is an unknown quantity at this point
Default RE: Supercharger prep
If the engine needs a rebuild then go with a set of blower/turbo pistons with the ring lands placed lower down for protection. One's that are made for the Sy/Ty application would be a good choice. I'd go with a forged for sure.
The Vortec heads you have are a perfect fit.
Look into the Marine intake or Sy/Ty intake for a long term solution for fueling.
ECU Programming with HPTuners or similar... larger injectors and a 225lr/hr fuel pump.
~Scott
Old Oct 17, 2008 | 05:05 PM
wienerdog's Avatar
wienerdog is an unknown quantity at this point
See if FelPro offers a LocWire head gasket, ARP head studs are standard fare for force fed engines. A 3 angle valve job on the exhaust. Upgrade the ignition with an MSD box or equivelent.
The bottom end will take a beating too, again, use ARP main studs and a main support if there is one.
You'll get used to 6 psi and want to move up.
Caution! Boost is habit forming.
Old Mar 10, 2009 | 03:50 PM
chevyracen's Avatar
chevyracen is on a distinguished road
injecters where do you get them
DetailersDomain
Detailing
Jan 26, 2011 09:02 PM
Fozzy
Sep 2, 2010 10:54 AM
RangerG
Jul 7, 2010 07:39 AM
Blazer Ken
Jun 27, 2008 11:54 PM
SmokeU
Jan 30, 2008 11:07 AM
