94 s15 jimmy lift ?'s
Old May 17, 2009 | 08:28 PM
GMCMUDDER's Avatar
GMCMUDDER is on a distinguished road
Default 94 s15 jimmy lift ?'s
well im new to here so whats up ppl.....well i have a 94 jimbo and im getting ready to lift...thinking of doing a 3" body lift and a 2" rough country suspension lift or maybe just the 2" suspension lift with 31' BFG MT any suggestions?
Old May 17, 2009 | 08:32 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
you only need 2" of lift to fit 31's however you achieve the 2" is purely up to. i would suggest doing some searches and get all the info you can on the lifts ur considering and weigh the pros/cons of each kit and buy whatever will suit you best.
Old May 17, 2009 | 08:41 PM
GMCMUDDER's Avatar
OK...ive read about the RC lift on here and every one has always talked bad about ball joints and all has any one had good remarks....or are ya'll just beating the crap out the ride and causing them to go bad?
Old May 17, 2009 | 08:48 PM
mikeinwi's Avatar
i thinks its more the cv's that get worn down with this lift not so much the balljoints, now i cant speak for each person and how they treat there blazers, but IMO you can get the same aount of lift by just cranking ur stock tb's. if i were in your shoes i would just go with the 3" body lift that way youll still have pleny of room for ur 31's and youwont be going through cv's like water. heres a good post about the 2" suspension lift gremlins and things to expect from the lift>>> https://blazerforum.com/forum/lifting-tech-44/2%22-suspension-lift-gremlins-26616/
eddiep23
Nov 9, 2011 10:25 AM
KMtorqe3000
Apr 25, 2011 10:33 PM
eddiep23
Lifting Tech
May 28, 2010 07:49 AM
aponeil
Lifting Tech
Mar 13, 2010 11:22 AM
bassgrinder
Mar 30, 2007 03:30 AM
