A couple pic's from a wheelin' trip the other day
Old Nov 6, 2013 | 11:36 PM
robsteez's Avatar
robsteez is on a distinguished road
Default A couple pic's from a wheelin' trip the other day
I went and did my first real trail the other day called the "hang glider" that takes you way up the mountain. It is not a stock freindly trail just because one part is abit tricky but the blazer pulled threw pretty good!
water hole
Hill climbing
Straight flexin
this is the top lookout point witch has a crazy view but we were fogged out, Found snow at the top!
Attached Thumbnails A couple pic's from a wheelin' trip the other day-robsteez-56368-albums-blazer-33-s-7494-picture-water-hole-27784.jpg   A couple pic's from a wheelin' trip the other day-robsteez-56368-albums-blazer-33-s-7494-picture-brap-27786.jpg   A couple pic's from a wheelin' trip the other day-robsteez-56368-albums-blazer-33-s-7494-picture-straight-flexin-27783.jpg   A couple pic's from a wheelin' trip the other day-robsteez-56368-albums-blazer-33-s-7494-picture-found-snow-27785.jpg   A couple pic's from a wheelin' trip the other day-robsteez-56368-albums-blazer-33-s-7494-picture-snow-shot-27787.jpg
Old Nov 7, 2013 | 06:43 AM
bigred01's Avatar
bigred01 is on a distinguished road
Nice shots
Old Nov 7, 2013 | 08:58 AM
El_Beautor's Avatar
Nice pics! Thanks for sharing. Have you tried disconnecting your front sway bar when you're wheeling?
Old Nov 7, 2013 | 03:12 PM
robsteez's Avatar
I have never disconnected my front swaybar but I keep my rear disconnected all the time. I wonder how much better disconnecting the front will be because without the rear it's a huge improvement.
Old Nov 7, 2013 | 05:04 PM
El_Beautor's Avatar
It helps a ton with keeping the rear tires on the ground in off-axis areas.
Old Nov 7, 2013 | 05:29 PM
robsteez's Avatar
ok cool thanks, I am gonna disconnect the front next time I go. what's it like driving on the roads/highway with the front disconnected?
Old Nov 7, 2013 | 09:36 PM
cwikk's Avatar
cwikk is on a distinguished road
What lift do you have? It looks great! 3"?
Old Nov 8, 2013 | 09:44 AM
El_Beautor's Avatar
I'd suggest just disconnecting it when you get to the offroad area. It's just 2 bolts to disconnect it, and you'll need to create an anchor to attach the sway bar when you rotate it up out of the way.
Driving on the road with the front sway bar disconnected will greatly increase body roll in corners, especially with your truck lifted like it is. If you tend to be more on the granny driving side of the scale you might not mind it at all. If you are more on the drive fast and corner faster side of things then you definitely do not want to drive on the highway or around town with the front sway bar disconnected.
jimmyonmudlites
Jul 25, 2013 09:28 PM
97OregonBlazer
Jan 4, 2012 01:36 AM
834x4s10on35's
May 23, 2010 10:35 PM
Puffie40
Nov 17, 2009 01:20 PM
Cow Killer
Aug 19, 2006 05:49 AM
