high low 4x4
Old Sep 13, 2011 | 02:07 AM
Big Ike's Avatar
Big Ike is on a distinguished road
Default high low 4x4
I have a 92 s10 Blazer. This past winter I found out that my high 4 wheel drive is went out, it will still go into low though. It has an electical switch so I thought maybe that went out but I do not understand why it will still go into LOW. Any thoughts?
Old Sep 13, 2011 | 07:40 AM
It may be a problem with the encoder motor itself not properly sensing the position of the shift sector shaft for 4HI. If this problem were to occur, it would revert back to 2HI.
Check out the thread below as well as a few other 4wd related threads in the Tech Article (DIY) section (index link can be found in my signature below):
NV233 transfer case / encoding motor switch
Old Jan 29, 2012 | 02:33 PM
wheninromeSDS's Avatar
wheninromeSDS is on a distinguished road
the 2nd gen has a switch on the transfer case. a little 3 prong thing that is open for 4 low and closed for 4 high. My 4 high didn't work, because the switch stayed open. I replaced the 20$ switch in 20 min, and my 4x4 worked again in high and low. I'd check into that.
jdiaz
Sep 26, 2023 11:29 PM
Streetracer94
Oct 29, 2018 09:33 AM
Hollywood2010
Sep 13, 2011 10:43 AM
LioNiNoiL
Aug 4, 2011 02:47 AM
fnbutch
Dec 12, 2007 07:29 PM
