lift kits
Old Mar 29, 2008 | 08:59 PM
96blazerfun's Avatar
96blazerfun is an unknown quantity at this point
Default lift kits
has anyone erver tried putting 45 inch tires with a 6 inch lift on blazer???
Old Mar 29, 2008 | 09:06 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: lift kits
not gonna happen... sorry
Old Mar 29, 2008 | 10:07 PM
WolfPack's Avatar
You'll destroy your drivetrain.
And fenders.
And you'll probably flip or roll, so your blazer too.
Negative ghostrider.
Old Mar 29, 2008 | 10:47 PM
Taymacjack's Avatar
typo alert typo alert...
Old Mar 30, 2008 | 09:45 AM
kankoon52's Avatar
kankoon52 is an unknown quantity at this point
you would have to do a solid axle swap with full width axles and a lot of choppin on your fenders. someday i plan to fit 37-40" tires on mine.
Old Mar 30, 2008 | 12:55 PM
94blueknight's Avatar
94blueknight is on a distinguished road
wow 45"s dang ya its called massive conversion lol might as well get a full size blazer frame and drop ur blazer body on it lol
Old Mar 30, 2008 | 03:13 PM
willjones's Avatar
I am going to hope that you ment to type 35's. If that is the case then yes you can fit them with some trimming. If you did mean 45's then there is absolutly no way.
Old Mar 30, 2008 | 08:54 PM
Rp9110's Avatar
Rp9110 is an unknown quantity at this point
45's or 35's? Because this truck (my friends 72 f250) below has 44's so 45's would be slightly bigger than that. You'd need alot of lift to fit tires that size on a blazer.
Old Mar 30, 2008 | 09:23 PM
nj4x4blaze's Avatar
Damm 45's???? Exactly you need a solid front axel and hack your truck to death to make the clear like the photo above. Get a full size truck if you want to run 45's.
Old Mar 30, 2008 | 09:36 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
save your blazer from abuse , go buy a monster truck.
