lift and tire??
Old Dec 2, 2006 | 03:37 AM
4x4blazin's Avatar
4x4blazin is an unknown quantity at this point
Default lift and tire??
i just bought a 00' blazer 4x4 4dr totally stock. i need help on what size suspension lift kit to go with in order to fit 33x12.5x15. any help would be appreciated thanks.
Old Dec 2, 2006 | 04:27 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default RE: lift and tire??
6 inch... minimal fender trimming....
Old Dec 2, 2006 | 01:55 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
more like 6" plus a 2" body for minimal trimming.....Im squeezing 31x10.5s into my blazer this coming spring, and I will be trimming even after my 2" body. If you only drive this on the road (which I doubt if you're getting 33s) then you might be ok, but as soon as your suspension starts flexing then you are going to get a world of rub.....
Old Dec 2, 2006 | 01:58 PM
a_tack's Avatar
im just goin by superlift reccomendations...... however, with their 6" F.I.T. lift, they reccomend 33X11.50's.....
Old Dec 2, 2006 | 02:03 PM
sledneck16's Avatar
yea man I edited that post but it didnt go through---didnt realize it was a 4dr--you're correct
Old Dec 2, 2006 | 02:31 PM
a_tack's Avatar
its cool... the 2 doors lift different because of the layout of the underside of the truck.... I kinda wish mine was 2 door but oh well...lol
Old Dec 2, 2006 | 06:51 PM
Hanr3's Avatar
Glad to see their are other knowledgeable members on this site. [sm=groupwave.gif]
Old Dec 3, 2006 | 01:06 AM
Jigg's Avatar
Jigg is an unknown quantity at this point
My brother has a 4dr 4x4 with a 2" BL, 1" tbar crank, shackles and 32x11.50 pro comp MT's. I highly doubt that you need another 6" of lift on top of that to clear another .5" of tire.
Old Dec 3, 2006 | 02:00 AM
a_tack's Avatar
is your brothers a generation 1 or generation 2???? cause I think hanr3 runs either 32's or 33's on his gen I blazer with 3 inches of lift...
you could squeeze it on there.... but it would run about like 31's do on stock height... it would rub like hell and do some serious fender damage.... now you can trim the fenders... maybe remove the inner fender and fit bigger tires... but with no body modification you have to have at least 6 inches of suspension to clear the 33's with absolutely no risk of body damage...... look at it this way.... procomp's website reccomends that you have a 5" lift to clear 33's on a silverado..... nw we all know the wheel wells are smaller on blazers... Pro Comp fitment chart
something else you may want to look into before running 33's on your truck is This link..... your tranny is not properly geared for that large of a tire.... well, i dont wanna get into it... just read the link.... the truck will work, but will not perform at its best.....
Old Dec 3, 2006 | 02:04 AM
Jigg's Avatar
ORIGINAL: a_tack
It's a gen 2. I ran 31's on my 97 2dr stock, so did he on his 97 4dr. Rim selection (width and backspacing) matters more than pretty much anything else.
Gearing depends on what you got from the factory. If you ended up with a GT4 (3.73), then the 33's aren't that bad. It's not a race car by any means, but it's manageable.
That chart is pretty and all, but it doesn't really apply to the real world.
