Question about offroading
Old Mar 12, 2009 | 06:52 PM
oisinirish's Avatar
Heavy Duty is definitely important. Get one of those cheap come alongs and the damn lever bends sidewise..... You'll be speaking in tongues!
Old Mar 13, 2009 | 07:50 AM
AllEiz0nMe's Avatar
AllEiz0nMe is on a distinguished road
This is true!!! Actually I'd probably be laughing my a$$ of at my husband and brother speaking in tounges. I could just see it now in my head. hahahaha
What do you think of the specs on this one?
4 Ton Neiko Double Power Puller Come Along 8000 LBS
  • Hardened and galvanized heavy gauge steel construction
  • Powerful ratcheting system is excellent for pulling heavy loads
  • Use with slip hook, wire grip, attaching clamps or other accessories
  • 1/4" diameter x 12ft aircraft cable
  • Pulling up to 4 ton (8000 lb) capacity
  • 5/16" safety catch hooks handle heavy loads
  • Safety automatic, notch at-a-time letdown thumb control release
  • Spring-loaded release lever for unwinding cable
  • steel ratchet handle with padded non-slip grip
  • Ideal for fencing, landscaping, boating, construction, and many other applications
Old Mar 13, 2009 | 09:36 PM
Bigringtravis's Avatar
Bigringtravis is on a distinguished road
Originally Posted by bandidolenny
One of the best and cheapest tools you can use to get unstuck is a high lift jack. When stuck in mud or sand i simply jack up one end of the vehicle as far as I can and then push the whole thing over. Do the same at the other end and your are out of the ruts. It also can be used as a come along / hand winch when equipted with hooks at the ends.
Nothing is more usefull IMO... That and, a few straps and a few feet of chain, D-Rings, Shackles. The bumper hook is the best too but, you have to hook it under where the bumper bracket holds the bumper to the frame or else it'll pull the bumper up and tweak it out!
Good luck!
DesertStorm
Dec 26, 2014 10:41 AM
Logan
Dec 3, 2009 12:11 AM
FarkDaNarc
Nov 20, 2005 07:04 PM
zero psi
Oct 17, 2005 05:00 PM
m00nwater
Sep 23, 2005 04:38 PM
