RATIO??
Old Mar 3, 2007 | 01:29 AM
Chevyguy032's Avatar
Chevyguy032 is an unknown quantity at this point
Default RATIO??
Do you guys think its safe to run a 33x12.5 tire on 3.08 gears? or is it pushing it?
Old Mar 3, 2007 | 09:15 AM
Default RE: RATIO??
It will be pretty gutless with that tall of a tire and 3.08 gears, but you should get decent highway gas mileage if you can keep it in OD... LOL
Old Mar 3, 2007 | 09:54 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: RATIO??
That 3.08 is a weak number, mainly good for top end speeds and gas mileage.
Try a 3.42.
Old Mar 3, 2007 | 11:56 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: RATIO??
I had 3.08s on my old silverado with 35x12.5 tires and it had no *****. I swapped them for 4.10 and it made a huge differance. Are you doing mostly on or offroad? If using it offroad, i was told by Goat 4.10 would be good. otherwise I would use 3.42-3.73.
Old Mar 4, 2007 | 09:37 PM
Default RE: RATIO??
yea..well i am going to eventualy lift it 6 inches so i was thinking 4.10 or 4.56 the most..but the front diffi has to be .01 higher..and when i look online for the gears i can never find a .01 higher?? (EX only 4.10, NO 4.11) or does it all come in one set?
Old Mar 6, 2007 | 04:45 PM
barsy07's Avatar
barsy07 is an unknown quantity at this point
Default RE: RATIO??
A 3.08 and 33's? it can be done... but why would you want to?
Old Mar 7, 2007 | 12:27 AM
Hanr3's Avatar
Default RE: RATIO??
3.08 and anything bigger then stock will kill your tranny.
Old Mar 8, 2007 | 12:20 PM
drperry's Avatar
Default RE: RATIO??
I don't think the front diff HAS to be .01 higher... I think that's just to offset the fact that it's got the engine over it...
If both diffs have the same ratio, you'll probably be able to leave it in 4x4 with less issues on pavement (like if you forget to knock it out of 4x4 when you get back to the road)
Kinda like the AWD vehicles... I don't think the front and rear diffs had different #s... that would cause major issues when running on pavement for a long time...
Now, keep in mind I'm a little on the tired side, so hopefully, one of the experts who knows what he's talking about can come and correct me, lol
Old Mar 8, 2007 | 08:38 PM
Default RE: RATIO??
ORIGINAL: Hanr3
yea but does it help that i have the 4 speed manual tranny?
Old Mar 8, 2007 | 08:39 PM
drperry's Avatar
Default RE: RATIO??
It'll help slightly... but not a whole bunch
