tires 4x4
Old Mar 17, 2011 | 04:50 PM
brandon42166's Avatar
brandon42166 is on a distinguished road
Default tires 4x4
I got a 1999 ls 4 door 4x4 ...i currently got 235/70r15 on there what is the biggest 15 I can put on there with everything being stock? also what would it cost me to get a three inch lift?...any suggestions?....where are you guys finding brush guards and other accesories at?...seems like aftermarket parts are getting hard to find...
Old Mar 17, 2011 | 08:12 PM
leeclark's Avatar
leeclark is an unknown quantity at this point
tires i think that 30x9.50x15 is biggest you can go stock. lift you can get a 2 inch body lift for about 200 dollars. lift shackles and tbar crank can get you 1 to 2 inches.
Old Mar 17, 2011 | 08:59 PM
Benedict1337's Avatar
yea sounds like you want a body lift and a tbar crank should give you 3-4 inches. largest tire you can fit right now are 30x9.5x15 if you get those two lifts you can fit 32x11.5x15's
Old Mar 18, 2011 | 02:17 PM
Thanks guys for the help.....where is a good place to get the shackles and about how much they cost?
Old Mar 18, 2011 | 05:47 PM
leeclark's Avatar
ebay and they run 50? not sure what they run just look em up
Old Mar 18, 2011 | 08:04 PM
Yea 50 is probably the cheapest good one you can get. U can get the ones at advance auto for 30 but they have no reinforcment so ur better off getting the better ones
Old Mar 18, 2011 | 08:39 PM
thanks guys....uve helped out a lot
Old Mar 25, 2011 | 12:23 AM
MeFrans's Avatar
MeFrans is on a distinguished road
I would say you can go to auto zone and buy a $16 shackle lift for the rear end. then raise your torsion bars up a bit to level it out and you will have about 2.5 in. cheap lift. then you can put 31x10.5x15 tires on.
Old Mar 25, 2011 | 08:15 AM
autozone shackles are not quality built, you risk twisting your leafs, and having the rear axle uneven which will create a very unpleasant ride
Old Mar 26, 2011 | 09:42 AM
litterbug's Avatar
yeah. but when you get new shackles get new bushings too. be prepared to have a hard time doing this. i started it one night thinking ill just unbolt the old ones and put the new ones on.... no the case. took me almost 2 days to finish.
