truck wont accelerate after fun in mud
Old Mar 12, 2008 | 10:28 AM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
Default RE: truck wont accelerate after fun in mud
if you can see those pics you should be able to see what i was talking about. those are from the left side and tehn right side.
*EDIT by swartlkk* - fixed image tags. removed attached images.
Old Mar 12, 2008 | 10:36 AM
woodsballr's Avatar
i figured out what been bothering me about it... it runs fine in park or neutral, its only when itsmoving that it does it.
Old Mar 12, 2008 | 10:43 AM
Unless the muffler is plugged up, this should not affect the operation of the motor...
Does the engine rev freely in park/neutral?
Old Mar 12, 2008 | 10:46 AM
woodsballr's Avatar
yes it does, it sounds like the hole is bigger but it runs smooth in park/neutral. only when its moving does it act that way.
Old Mar 12, 2008 | 10:52 AM
More fuel is necessary to move the vehicle. Just like more spark power is necessary for complete combustion. If it isn't a fuel issue, then it is possible it is a spark issue.
Old Mar 12, 2008 | 10:54 AM
woodsballr's Avatar
ok. thanks a whole heap. i gotta head off to school so i dont get counted absent for the day. i'll look at it more when i get home.
Old Mar 13, 2008 | 08:54 PM
woodsballr's Avatar
i checked all my spark plugs today and they're good,the distributor is good too so i bought a new fuel filter that i'll replace tomorrow.
Old Mar 14, 2008 | 03:27 PM
woodsballr's Avatar
replaced the fuel filter just now and it didnt fix it. i took it for a drive after that and the first 1/4 inch of pedal it drove fine, after that it sputtered, and the sound came from the back if that helps any, and it would slowly pick up speed. it did it at idle too when i revved it in park but also keep in mind it had just been started up for the day. should i take the exhaust off and see if that helps?
Jimmy Williams
Aug 6, 2021 08:24 AM
btmbass
Apr 25, 2011 09:39 PM
tony991
Dec 18, 2010 02:39 PM
mysons95
Oct 29, 2008 04:58 AM
prozach1988
Feb 23, 2008 07:39 AM
