what do i have to do???
Old Jul 16, 2009 | 07:03 PM
trobbins's Avatar
Default what do i have to do???
I have been told if i put to much of a lift on i have to change a bunch of crap. what is the biggest i can put on with out changing that stuff? and what would be the best way to do it. and what size tires can i put under that lift?
Old Jul 16, 2009 | 09:25 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
what are you driving?? how much lift do you want?? what size tires are you wanting to run?? almost every lift will require you to change something, do some searching around there is a ton of info about lift kits on this forum.
Old Jul 17, 2009 | 12:38 AM
bandidolenny's Avatar
I wouldn't go bigger than a 12" lift with 44" tires...
Old Jul 17, 2009 | 02:03 AM
okvortec's Avatar
Old Jul 17, 2009 | 12:28 PM
trobbins's Avatar
im in a 97 4dr 4x4 blazer, if i put on a 5-6" lift with 35's what all would i have to change?
Old Jul 17, 2009 | 12:38 PM
mikeinwi's Avatar
you wont be able to fit 35's with only 5-6" of lift youll be able to run 33's or 34's with a good amount of trimming and if your still asking what you have to change i take you havent used the search function yet....
Old Jul 18, 2009 | 11:25 AM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
if I may be so Bold....
learn to Crawl before you enter a marathon...
Meaning, start with a 1.5" Tbar lift and maybe a 2 " Body lift
go with some 30s... play around like that for a bit.
You wont have to change your gearing or anything radical.
Save the 10" Lift with SFA and Dana 44 swap for later.
Old Jul 19, 2009 | 11:43 AM
trobbins's Avatar
so if i put the lift on i want what things will i have to change
Old Jul 19, 2009 | 11:44 AM
trobbins's Avatar
and im not wanting a 10" lift, im just wanting a 5-6"
Old Jul 19, 2009 | 07:45 PM
A complete 6" lift should come with everything needed including shocks. You will then want to install up to 33" tall tires on 8" or 10" wide wheels. After that, have the front end aligned... And you will probably want to re-gear the axles... It's just that easy! It only takes $$$... (alot of it)
