where can I find a lift?
Old Nov 17, 2005 | 09:53 AM
86S10blazer23's Avatar
86S10blazer23 is an unknown quantity at this point
Default where can I find a lift?
I finally got my blazer... it's a 4x4. I have been looking in my free time for a lift for it but my searches leave me nothing, I even went to suspension companies to see if the even make them for my truck, and still nothing. I know there's somebody out there with a lifted s10 blazer... mine's an 86' if anyone has any info as to where I may find a lift, let me know, thanks, Greg
Old Nov 17, 2005 | 07:02 PM
drkmelvin's Avatar
drkmelvin is an unknown quantity at this point
Default RE: where can I find a lift?
here you go...scroll down to your truck http://www.airbagit-store.com/produc...t.asp&ID=92506
Old Nov 18, 2005 | 04:31 PM
Hanr3's Avatar
Try searching for TrailMaster, or SuperLift. I know TrailMaster makes a lift kit, and I have heard that Superlift does as well.
Until you get it lifted, you can run 30" mud tires with no modifications. A 2" body lift and you can run 31" tires. With the 5" TrailMaster suspension lift and the correct back spaced wheels, TrailMaster recommends 32" tires. I don't really think its worth $1300 for 1/2" more ground clearance.
Old Dec 13, 2005 | 03:09 AM
keethkhg's Avatar
keethkhg is an unknown quantity at this point
It is an older truck you should really consider the tried and true method of cutting the fenders. Add some fender flairs, JC Whitney makes some cheap ones, and it will look fairly clean. That and a 3” body lifts and you can have some fun. Then you should be able to run 32”s with out any trouble. I have not done this though, so it is all hypothetical. Good luck.
Old Dec 13, 2005 | 03:44 PM
Hanr3's Avatar
ORIGINAL: keethkhg
Not hypothetical.
I have a 3" body lift on my '87 S10-Blazer 4x4x2 and have 33" tires. I had to trim the fenders and will post pics if your interested. Trimming the fenders wasn't bad and the chrome ring around the fenders covers the cuts up nice. I'll try to post a tech article tonight, if I can get the computer from my son.
Hizapitt
Mar 15, 2010 07:27 PM
Houchins.23
Lifting Tech
Feb 14, 2009 06:36 PM
95LS
Lifting Tech
16
May 16, 2008 06:05 PM
Dammit97Blazer
Mar 9, 2006 11:52 PM
LoLoS10Blazer87
Jan 20, 2006 05:12 PM
