^^^no, Logan is doin' a SAS in his ZR2.
you keep mentioning "i will be able to fit the zr2 rims under it.", stop mentioning the rims-it's the tires that are the issue! you're trying to fit 31's on your truck, right? sorry, but when you keep going (defaulting?) back to this statement, it sounds like you're not listening to what is being said. i could take a setof those ZR2 styled wheels and put on a 55 series tire, and they'd still fit the truck. would look pretty stupid, but would still fit. and the ZR2 t-bars will just give you a stiffer ride. here, check THIS out. it's give you some more insight into what you're trying to accomplish. you can also check this out as well. hope this helps you out a bit more. |
(Post 285131)
Ok... I'll sum everything up that's been said by everyone for you man.
ZR2 rims are the same as any other 4x4 Blazer rims. The tires are different. They're about 1" taller than the 235's T-bar crank is good for the road, if you want to do offroading, look into a 2" body lift to go with the t-bar crank. You will only end up rubbing the sway bar at full lock and articulation on the trails. (Not a big deal IMO). Don't get wheel spacers as in some cases this makes fender rub worse (unless my logic is flawed...) The ZR2 sway bars only create a stiffer ride, I remember reading a thread in the Suspension Tech section where someone did the swap and was pleased... you won't gain any ground clearance from this swap unless the original T-bars are weak in which case they'd be sagging and the front end would be low to begin with. good luck. |
:icon_ditto: thats it in a nutshell Pat.
if you haven't decided on the truck you want yet, just narrow your search for a ZR2. if you get a regular 2dr, add a body lift, get some good 31" tires (5) and convert over to 3.73 gears, you will be looking at the same price as just paying for the ZR2. BUT the zr2 comes with some other gains (both small and large) to include a stock SUSPENSION LIFT. SO if you just get a ZR2 out the gate, you will be set back a little more in the begining, but make up for it the first time you put together your wish list of mods to do. half should already be knocked out for you. as for fitting 31's on a normal 4x4 blazer (2 or 4 door) just open 5 random threads. two should cover that.... seriously. 2" BL OR +1.5-2" T-bar if all you want is the road. Both if you want to off-road with out too many problems. to even it out in the rear, toss an add-a-leaf on it OR +1-2" rear shackles. done. |
Originally Posted by oktain
(Post 285190)
Originally Posted by Spectreblazer
(Post 285233)
thanks for summing it up. so if im understanding this right i can put 31s on my stock rims do the tbar crank, shackles in the back and call it a day.
Originally Posted by leeclark
(Post 285244)
Yes unless your gonna be doing some off roading. you can check my blazer out it has the tbar crank and shakles with 31" tires but they do rub at full turn
30's with a good agressive tread would work... you can try 31's off road with just a crank, and if you find it rubs with the stuff you're doing, do a body lift then.
(Post 285254)
(Post 285190)
not nit-pickin', just getting the facts out there. |
