Winch set-up advice
Old Dec 12, 2017 | 12:46 PM
Can someone confirm the ad244 alternator upgrade is the one to which I made reference above in which an alternator is used from a full-size truck?
Old Dec 12, 2017 | 01:00 PM
Yes. I pulled mine off a Tahoe with a 5.3l V8. Direct bolt on, requires a slightly longer belt because it's physically larger. I installed one because of electric fan conversion, car audio equipment, auxiliary lights, and now a winch that I'm installing.
Old Dec 12, 2017 | 02:53 PM
Yes. I pulled mine off a Tahoe with a 5.3l V8. Direct bolt on, requires a slightly longer belt because it's physically larger. I installed one because of car audio equipment, auxiliary lights, and now a winch that I'm installing.
This is perfect. Thanks! This is definitely going on the "to do" list.
Old Dec 12, 2017 | 03:08 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
Another option if you want to up the capacity of a smaller winch is to use a ****** block.
Doubling your pulling power
Another type of winch rigging that uses a ****** block is the double-line pull. There are two common situations in which the double-line pull is useful. The first is if you think your winch doesn’t have enough muscle to pull out your vehicle. The second is if you want to recover a vehicle that’s bigger than yours.https://www.gowarn.com/warn-winches/winch-tips.aspx
Old Dec 12, 2017 | 09:40 PM
deleted post. I'll ask again later after I think about it a bit.
Old Dec 12, 2017 | 09:49 PM
Lefet's Avatar
Lefet is on a distinguished road
I do believe, if set up properly and of course you have the necessary anchor points, a ****** block (probably 2) would accomplish the mission. Then you wouldn't have to worry about damage underneath. I imagine a ****** block on a tree behind the vehicle, maybe 2, one offset of the vehicle, cable run through then attached to the rear of the vehicle?
Old Oct 26, 2018 | 01:37 PM
bajablazer93's Avatar
bajablazer93 is an unknown quantity at this point
I use a smittybuilt 9500xrc with ****** blocks. Got it for about 300 and it has worked pretty good, just make sure you have a beefy bat before you do.
Old Oct 30, 2018 | 12:18 PM
I'm running a Warn M12000 on mine with dual batteries and an AD244 alternator. I haven't had any issues, even though the full-load amp draw is something like 440 amps.
While any winch is better than nothing, I'm also a believer that you shouldn't skimp. Buy once, cry once.
Coleman Mason
May 16, 2016 07:46 AM
ckroll98
Nov 4, 2013 01:47 PM
Blazerboy8692
Aug 13, 2011 08:14 AM
96chevblazer
Nov 8, 2009 09:42 PM
deegan26
Aug 4, 2009 10:06 PM
