2000 Blazer Radio Delete Panel
Another Radio would be okay, but even if I had one, I wouldn't listen to it all that much...plus I'm not certain exactly how to install it. I imagine that it is easy, because the thieves had no problem taking it out, but Googling on it just confused me, because they made it appear to be fairly complex.
Of course, the speakers and cables are all still there, so I imagine that it is just getting a radio to fit the hole, and that would match the cable connectors. but what would hold it in place in the hole?
As far as making a panel, that doesn't seem like such an easy idea to get something that didn't look like a huge bandaid.
Installing a new stereo is simple. First, did it have the stock stereo? If it was aftermarket, you'd need a dash kit. You just pull the bezel off your dash, there will be some plugs to unhook (dash switches and what not) then it should be completely off. With that off, you'll see how the stereo stays in the dash. Usually some screws of some sort. If it's aftermarket and you have the aftermarket wire harness, all you have to do is color match wires. If it's the stock stereo, simply plug the harness into the stereo and plug the antenna in. If you'd like, if you decide to get a new stereo, I can walk you thru it step by step to make it easy.
Remove the bezel, what bezel...one just around the radio itself, or the entire dash bezel? It is this factor that I came across Googling, that made it look unnecessarily complex, as can be seen in this video:
https://www.google.com/search?client...hannel=suggest
If the entire dash bezel, then I would prefer to just use a delete panel as I mentioned. However, looking at the radio hole itself, I see nothing that appears to be designed to support a radio. I suppose that could be accomplished with an exterior panel through which the radio control **** shafts go protrude, but that wouldn't support the aft portion of the radio, where most of the weight is.
EDIT: As for whether the old radio was OEM or aftermarket, I have no idea, because I'm not sure what the OEM radio looks like.
I think the radio delete panel that would work was part# 10197485, but it's discontinued. That is the part# for the radio delete panel that was used in police package Caprices that were ordered with no radio.
Easier option would be to buy a radio install kit and glue a piece of thin plastic over the entire front to cover the hole.
mickey_bigdaddy
Jul 21, 2015 07:58 AM
Boiler20
Oct 19, 2013 03:53 PM
chevblazer02
Oct 31, 2006 09:36 AM
