74 K5 Doors
74 K5 Doors
Does anyone know where i can buy door shells for a 74. Seems like everyone has up to 72 and 76-91. LMC, Classic ind,Car parts wholesale, nobody has em, i would just buy patch panels but by the time i pay someone to do it, might as well bought a door. Any help would be great!!!!
You have to cut down the full frame doors to work. Add in the few reinforcing brackets used and drill some extra holes. I'll be doing this with my '90 Suburban doors for use on my '74. I will be picking up another '74 for parts and using the brackets from those doors so I do not have to be door-less during this time. The first bracket is under the plate on top of the rear of the door. It is what the plate screws down to. Then the other bracket is on the rear window track. You have to cut down the rear window track from a full frame door, remove it's bracket, then add the bracket from the convertible door.
I have already had to do the conversion of the rear window track on my passenger door as I had my rear window track break and just happened to have a full frame rear window track on the bench in my garage... I did not take any pictures though.
thanks for the reply, sounds like alot of work, hope all goes well with yours. So its just drilling and bolting. sound easy enough. I will get a better look at it when i finally get home from Iraq, as this is my first K5
There is some welding involved. Other than that, it is not too awful bad. When I do my spare doors, I will document it quite well.
Some photos or something would be great, thanks alot
ProjectICE
06-21-2011 03:22 PM
celchlepp
02-17-2008 03:56 PM
dropd4door
02-10-2006 02:34 PM
