97 Bravada steering wheel adapter
I want to put my aftermarket grant wheel on my 1997 bravada. What steering wheel adapter do i use?, When i ask around at local parts stores they tell me "I can't buy one for it". Probably because it will eliminate the airbag. Do i just buy one for the older body blazer? Or do i have to make my own adapter?
Just so you know, it is illegal to switch an airbag equipped vehicle to a non-airbag steering wheel. I'm not telling you not to do it, just wanted to make sure you knew.
Grant does make customer steering wheels with air bags built in.
In pa im a mechanic, At work i can not legally fail a car with out a airbag"and the light bulb out", I can fail it for a deployed airbag that is still present, but not for a removed airbag. Just like if you have bad struts that are leaking oil i have to fail it, But if they are blown and not leaking oil I have to pass it. lol
Thanks for the info, I will check into the grant adapter.
Yea the adapter is priced insane, I was gonna look into using a steering column from a 94 s-10 truck, They do sell a steering wheel adapter for that since it does not have a factory air bag. I just dont know if the s10 column will work yet, I will let you know
luigi408
Dec 19, 2009 09:20 AM
dlcrawle
Jan 28, 2009 08:59 AM
