wheel adapter and wheel choices
Old Jan 27, 2014 | 08:23 PM
welderman85's Avatar
welderman85 is on a distinguished road
Default wheel adapter and wheel choices
hi I have a few choices and cant decide what to do. I have had this jimmy for 6 years and need to change it up a bit. the first attachment is how it was for a long time untill studs broke and trashed one wheel so I went back to stock to get buy but now I need a change. so here are my chocies. I have old style zq8 wheels in the barn I could use I also have a set of 15" bullet hole American racing wheels from my old two wheel drive full size that would fit with adapters or door number 3 I have a set of newer 17" jeep jk sport wheels. the jeep wheels and full size chevy wheels are both 5 on 5 so I will need adapters. what do you guys think would look best. thank you
Attached Thumbnails wheel adapter and wheel choices-20120115_10.jpg   wheel adapter and wheel choices-fdbadbfb.jpg   wheel adapter and wheel choices-untitled.png   wheel adapter and wheel choices-wheels.jpg   wheel adapter and wheel choices-ghg.jpg
Old Feb 15, 2014 | 12:13 AM
Neb15's Avatar
Neb15 is on a distinguished road
I personally like 5 spoke designs, If I had to pick one id go for the jeep rims altho not very shiny. Might be interesting to check the chop shop and see if somebody will photoshop em on for you. Side note, how did the firestones work for you?
Old Feb 15, 2014 | 09:22 AM
El_Beautor's Avatar
I'm fairly certain that I've seen someone running a set of Jeep wheels like those on here within the last few months. I'm pretty sure I saw it in a show off your rim/tire thread but I can't find it at the moment. If you can find the thread it would give you an idea what the Jeep rims would look like on your Blazer.
**EDIT**
Found the thread for you. Was a lot harder to find than I thought it would but I'm way too obsessive about things and I just couldn't let it go. Now just FYI, it's pretty obvious that he's running a fair bit of lift and a solid axle swap.
Originally Posted by KM346
Wrangler Rubicons....
Old Feb 16, 2014 | 08:59 AM
Thank you for looking that up I like the look of that
hotrod413
Engine & Internal
Sep 25, 2009 04:30 AM
c5ce
Jan 17, 2009 11:37 AM
ratical12001
Lifting Tech
Feb 22, 2008 09:51 AM
dbleon
Jan 23, 2008 04:35 PM
jagblazer01
Jul 13, 2006 01:27 AM
