Body lift install
Old Jan 5, 2009 | 07:28 PM
NVANZEE's Avatar
Default Body lift install
Im installing a PA body lift this weekend. Is there any tips or tricks i should know of before installing it.
Old Jan 5, 2009 | 10:23 PM
WolfPack's Avatar
Default RE: Body lift install
1. use the BDS instructions
2. dont forget to take off the ground strap on the passenger side firewall, by the hood.
3. dont try to remove the filler neck till after you get the lift pucks in. Disconnect, but do not remove till lifted...much easier
4. The directions go through a pretty lengthy process of relocating and dropping the (+) dist. block beneath the battery. Mine had plenty of slack and did not need to be even loosened.
5. The body mount bolts will be on pretty tough, mine came off easily with 2' of pipe on the end of a 3/4' drive ratchet (I didnt pre-soak with PB blaster)
Those were the big ones for me...I'm sure others have found a few tricky spots as well
Take before and after pics!
Old Jan 5, 2009 | 10:35 PM
NVANZEE's Avatar
i plan on having the bolts soaking in pb all week starting tomorrow. What kind of thread lock should i use
Old Jan 6, 2009 | 02:27 AM
WolfPack's Avatar
The PA kit comes with some red locktite
Old Jan 6, 2009 | 07:10 AM
NVANZEE's Avatar
ok thanks
Old Jan 10, 2009 | 10:59 PM
NVANZEE's Avatar
im in the process of re-installing everything after the lift. Did you have any problems with the radiator hose inlet on the left hitting the belt.
Old Apr 2, 2010 | 07:46 AM
98jblaze's Avatar
98jblaze is an unknown quantity at this point
i don't know what bds stands for i need the instructions to do a body lift just don't know what bds stands for please educate me thanks
Old Apr 2, 2010 | 11:42 AM
TRX's Avatar
TRX
TRX is on a distinguished road
These are the instructions I used for my 98 LT.
http://www.bds-suspension.com/pdfs/9228.pdf
This is the BDS main site.
btmbass
Lifting Tech
Mar 24, 2011 04:04 PM
Blazn1
Lifting Tech
Jun 20, 2009 12:08 PM
flyinbrad
Sep 21, 2007 11:13 AM
booblinker
Nov 2, 2006 02:59 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
