Body mount bushings
Old Jul 15, 2012 | 01:11 AM
neo71665's Avatar
I'm willing to bet you have more than 4 bad. They might look fine but once you replace with the new you will find out they have sagged or they fall apart when you loosen them to put the new ones in. The rubber gm used degrades pretty fast.
Old Jul 16, 2012 | 01:11 AM
Blazin_Jason's Avatar
Looks like LMC has them. But by the time you get 4, might be worth getting a full set.
Old Jul 18, 2012 | 07:51 AM
Coddrick's Avatar
Coddrick is on a distinguished road
yes, I was too lazy to check, at the time of posting this, but I am quite certain that LMC does offer individual bushings.
Old Aug 19, 2012 | 05:54 PM
richphotos's Avatar
Well, I got the bushings, to do the cab mount, but how the hell do I get the old bushings out on my 93 jimmy 4wd? Is there a bolt with a nut? or is it just a bolt, because I pulled back the carpet and could not find a nut on the top side?
Old Aug 21, 2012 | 01:22 PM
neo71665's Avatar
There is a nut welded in the floor. Hopefully you can get all the bolts out without any problems.
Old Aug 21, 2012 | 02:06 PM
richphotos's Avatar
I hope so too, when I pulled up the carpet, the floor is in great shape. Looks like i'm getting a new can of PB blaster and soaking them all
Old Aug 22, 2012 | 06:56 PM
okiedoak20's Avatar
my local gm stealership wanted $35.00 for each body mount, then i found a energy suspension full body kit online and was a lot less costly. scense i was doing a body lift i may as well do the mounts also..
Paul Bell
Oct 13, 2011 06:56 AM
Diverknox
Mar 4, 2010 10:05 PM
Drifter666
Sep 15, 2008 02:35 PM
95Blazer4x4
Feb 1, 2008 08:19 PM
lennyblazer
Lifting Tech
Jul 16, 2007 11:58 PM
