Body mount retainers
So I had to lift the body and in the process the 2 kick panel bolts one was rusted in 2 and came apart as soon as I touched it. The other the retainer broke and so i cut the head of that bolt.
Good news all repairs are done except those 2 kick panel bolts. I plan on just cutting the floor above them and then cutting the retainers out and either:
A: drill the bolts out of the retainers with an 11mm drill bit on the drill press and then weld it all back together.
Or B: cut 2 out of my donor vehicle and weld it all back together.
Is there another option that I'm not seeing or thinking about that don't involve cutting huge holes in the floorboard?
Thanks in advance for any knowledge, advice or ideas.
I would think about cutting the floorboard with a hole saw to get the old nut/retainer out, then dropping a bolt with a washer down from the top, putting a nut on the bottom, and using a snap-in plug to cover the hole.
unfortunately to cut the retainer strap to get the retainers (and remainder of bolts) out. It requires a much larger hole about 4" using the smallest cutting wheel I've got to cut the straps. I can probably save these or I've got a parts Blazer I can cut the retainers out of it and then weld the retainer strap back together.
Just wasnt sure if through the floorboard was the best way or if I was in a mind rut and couldn't see the easier way that could be right in front of me. Sometimes I get an idea in my head and I cant see around it. Often my ideas are not the easiest way. I am a chronic over thinker. Lol They still work, just takes more time and effort than what is required. Lol
