boneyard grille guard - restore
picked up this gem for 30 bucks.
i figure i can wheel the hell out of it and etch prime and paint/ bedliner in a can this bad boy.
anyone have any advice before i get to work, as in having done this and any areas i should be aware of. should be straight forward restore and rust treat.
thanks
thanks
Nice find!! Wish I could find something that cheap.
As for the restoring, looking at how rusty it is you may want to invest in some Rustoleum primer just to ensure the best bond possible. Either that or some specially formulated rust primer. Obviously try and get as much of the rust off as possible. It looks like mostly surface rust so I don't see you having much of an issue.
Couple coats of primer and a couple coats of paint should do it. Any thoughts on using undercoating for a finish?
BTW - Your Blazer is nearly identical to mine but 4dr lol. We both have the painted rims and the tinted lights. Lookin good!
great minds think alike...mine is four door because i needed a family cruiser that i could still play with.
yup the steel is still solid, only surface is rusted. it came off pretty easy which was a bonus. the only hang up is that it came off a cherokee. the width is fine, just needs a little massaging with the cutting wheel. to small bumper mount brackets that are coming off.
i fig. i would wheel it and use some rust "converter" primer and/or metal etcher.
i also was going to finish the job with the good old bedliner in a can that i used on the rockers. it is cheap and easy. then later light that baby up!!!
use POR-15 for the base coat. it's a primer & a sealer-works amazing! the only draw back, it's not UV friendly. but considering how your truck sounds alot like Alex's, it'll work just right for you.
the UV rays turn any of the blacks to a dull "flat" finish. the paint doesn't come off-in fact it's pretty durable. it lasted 6 yrs on my drive shafts before any indication of rust (probably guessing stones finally chipped the paint).
if you use the POR products, just follow their directions-to the "T". in fact, if you just brush off the loose 'n flakey stuff off the push bar, it'll stick better than using a wire wheel to remove it.
here's a link to their site;
POR-15 paint
GL with your resto job.
POR-15 paint
well, i haven't given up on the guard...holidays are slowing my progress a little bit.
i have it stripped and am working out the mounting details (cardboard mockup)
i will report in when i make some progress.
damn it man! get out of my build! first you pull off my dream two tone rockers now you are converting another grille guard to work on you truck! damn you and your ability to finish all of what i put off!!!
that being said, my brush guard only has some surface rust. a lot less than yours, but my plan was the same: wire brush it clean, converting primer, bedliner in a can, reassemble and mount to fabbed brakets! hope you make some good progress! keep us posted!
