Bravada wheel painting - Step by step with pictures
Old May 18, 2011 | 07:04 PM
rudd21's Avatar
rudd21 is on a distinguished road
Default Bravada wheel painting - Step by step with pictures
I had been kicking around the idea of painting the stock wheels on my '97 Olds Bravada since last summer, but never took the time out to actually do it. I finally commited to it as a two day project a couple weeks ago and thought I'd share my results. First let me say that I didn't do this the quick or easy way. I went about this project in the same way one would a typical autobody repair; Sand, Prime, Basecoat, Clearcoat. Heres how it went down:
Before:
Washed wheels down with soap and water. Wiped down with Wax and Grease Remover.
Sanded down rough/correded areas with 150 grit then followed up with 400 grit over the entire wheel. Wiped down thoroughly with Wax and Grease Remover.
Masked off, ready for primer.
Although these stock wheels were completely painted with little bare aluminum, I chose to go with a self etch primer to ensure adhesion on the few spots that were bare. I used SEM brand primer.
Sanded wheels down with 400 grit. I decided to spray the silver rings on the wheels since the original silver had been sanded down due to corosion from wheel weights. I sprayed three coats of Dupont Chromabase BC silver for the rings. I tried to target the outer edges of the wheel when spraying, however I wasn't worried about overspray since the whole wheel would be painted over with black later. (Picture shown with silver dry, being masked off for black coat)
More masking for black coat.
Black wheels! Sprayed with Chromabase BC 99K black, three coats.
Black wheels with Bravada on jacks...
Clearcoat applied. I sprayed about five to six coats of Nason 497-00 Clear over the wheels. (very good clear for the price!)
Unmasking.
After:
For the lug covers I sanded them down with a red scotch bright pad, wiped them down, and sprayed with SEM adhesion promoter. From there they were sprayed using the same process, right along with the wheels.
This was my first real painting project since working at an Autobody supply store for a year and a half. The wheels didn't come out flawless but I am overall very pleased with the results. If you have any questions I would be happy to answer them.
Old May 18, 2011 | 07:10 PM
warthogdriver's Avatar
that looks great....amazing what a diff a little paint can make....great job and great write up.
Old May 18, 2011 | 08:41 PM
TheRandom1's Avatar
Wow that looks fantastic! Thanks for the write up, I'm going to have to follow this when I get around to refinishing my wheels.
Old May 18, 2011 | 09:05 PM
69chevelle's Avatar
69chevelle is on a distinguished road
you took a lot more time with yours then I did, I sandblasted mine, epoxy primed, 4-1 urathane topcoat(I do industrial painting, not autobody haha)
looks good!!! I like the little extra with making the lip silver...
Old May 18, 2011 | 09:10 PM
84BlazerS10's Avatar
Looks really good
Old May 18, 2011 | 10:00 PM
abig84's Avatar
actually looks pretty good
Old May 19, 2011 | 12:00 AM
nineTnine's Avatar
nineTnine is on a distinguished road
Very nice! I like the silver lip and emblem, both nice touches
Old May 19, 2011 | 12:23 AM
diRteh's Avatar
diRteh is on a distinguished road
Very nice..
Old May 20, 2011 | 05:39 AM
rudd21's Avatar
Thanks for all the compliments...
Old Sep 23, 2011 | 11:04 PM
gatorboy44's Avatar
gatorboy44 is on a distinguished road
I did the same with mine but i used Duplicolor engine enamel.
