De-badging
Old May 8, 2008 | 10:10 AM
Myerswelder's Avatar
Myerswelder is an unknown quantity at this point
Default De-badging
Does anybody have any pointers on taking all the badges off without scratching my paint. Are the "Blazer" emblems a stick on or do they mount into your doors?
Old May 8, 2008 | 11:04 AM
Zasder's Avatar
Zasder is an unknown quantity at this point
Default RE: De-badging
Get a heat gun and some fishin line...
Mine came off quite easy. Buy some Goo-Gone to remove the left overs, then wash the area, and wax it.
Old May 8, 2008 | 01:09 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
The emblems themselves are the easy part but the double-sided tape on the back om em and the door trim is kinda a pain to get off if you dont use fishing line. But after I got the tape offI used this stuff called spar cream and it removed all the dirt and other nasties left behind from the tape and it cleaned it nicely.
Old May 8, 2008 | 03:38 PM
yukonmedic's Avatar
yukonmedic is an unknown quantity at this point
i agree with zasder, minus the heat gun.
ahair dryer on high power works good, just takes a bit more time...i like to be ultra cautious when it comes to paint.
fishing line is a great idea, unfortunately i didn't have any handy at the time so i used the white nylon straping that they use for shipping boxes. pretty much anything thin and strong that doesn't have a rough surface.
once you have it off use goo-gone or something similiar to remove the leftovers, and give 'er a good wash!
Old Jul 15, 2008 | 04:20 PM
chevy Blaze's Avatar
chevy Blaze is an unknown quantity at this point
i have dont this before with a mitsubishi and i took a blow dryer and fishing line, then use rubbing alcohol and rub off any dirt or tackyness left over.
Old Jul 15, 2008 | 06:38 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
yea the nylon method is way I use
Old Jul 15, 2008 | 06:55 PM
cliro's Avatar
cliro is an unknown quantity at this point
watch your thumbs too, blisters are no fun.
Old Jul 15, 2008 | 11:53 PM
Drifter666's Avatar
Drifter666 is an unknown quantity at this point
a buddy of mine swears by WD40 he says spray alot on the tape let sit for a while then use a bath towel to remove it, i used nail polish remover and wd40 mixed together took some elbow grease but cane right off witch i thought was great considering it was 14yrs old
Old Jul 16, 2008 | 12:57 PM
zackbennett's Avatar
zackbennett is an unknown quantity at this point
If your using fishing line make sure you have at least a 25LB test or more, otherwise you'll be yelling at yourself when you break the line every quarter inch tape you cut with it. Just speaking from experience..
Old Jul 16, 2008 | 04:16 PM
redneck2725's Avatar
redneck2725 is an unknown quantity at this point
ORIGINAL: zackbennett
I came in here to say exactly this. I tried once with 12lb and it was horrible!!
