different kind of door pin problem
Hi I am kinda new to the forum. I have searched and can't find anyone else with this problem. I have done door pins twice now on my 02 2 door ls, the first pin set I got from Napa and the bushings went in tight with no problems and worked out for about 4 or 5 months but then the bushings started to seize to the pin and spin in the bracket and start to split. I took them out and got another set from Napa and they refunded my money for the first set. installed the second set, they went in tight and made it a weekly regiment to oil the pins. And again they are seized to the pins and started to split. has anyone else had this problem? Is there something I am doing wrong? Is the gm set any better?
Thanks,
Garrett
Thanks,
Garrett
Good points petty & I'd still use a good nickle anti-seize on the pins. Oil will not protect it the same & will displace, anti-seize will stay there a lot longer & lubricate. Though if they're bronze bushings they'll naturally lubricate... but I'd still add it lol.
Nice quotable quote btw in the sig today:
There are students and there are thinkers. A good student soaks up what he hears and reads. A thinker analyses and questions what he hears and reads. Some do both. But testing well does not mean you are a thinker.
-Ace
-Ace
D'oh! Stupid of me to assume one side was bolted and writing without looking.
Well, Gclaypool... the chance are good that at some time your truck was hit and the 4 hinge pin holes are out of line.
As to lubing, the hinge pin bushings if they are quality should be bronze oil-bearing type. Before I trusted anti-seize I would think moly grease
evuldrporkchop
Mar 30, 2013 09:01 PM
TouringMike
Sep 22, 2011 09:22 PM
thereverendbill
Jun 19, 2010 10:12 PM
