Door latch predicament,
Old Apr 19, 2024 | 04:00 PM
bldrofreal's Avatar
bldrofreal is on a distinguished road
Default Door latch predicament,
Any idea how to fix it? The metal around the latch has fractured. Thanks in advance
Door sags because the pins are messed up.
If i make a hard right my driver door flies open 😀
Old Apr 19, 2024 | 07:17 PM
AJBert's Avatar
You need to cut out and weld a patch into the body pillar. You also need to make sure you have the backing plate behind the skin in place. To be honest, your latch looks to be in serious trouble. Might want to make a trip to a body shop to have it done. Call ahead to hopefully find a shop that has done this before.
Old Oct 24, 2024 | 10:40 PM
Bass_Surfer's Avatar
Bass_Surfer will become famous soon enough
Don't remove the broken latch post panel as it is, you'll need to keep the dimensions as they are, but inside the B-pillar is free to mess with.
I'd scab another overlapping piece from another GM truck of the same vintage - and weld or braze it inside the existing cracked skin.
Then, braze up the cracks, making sure to include the inner new piece by brazing it into the existing outer piece.
Etch, Bondo, sand, prime, sand, paint.
step66
29
Sep 14, 2020 05:45 AM
Rudeness
Mar 28, 2018 04:58 AM
chcknugget
Jul 18, 2013 04:39 PM
low1
Dec 7, 2011 08:47 PM
95POSmoneypit
Sep 21, 2009 02:17 AM
