Body cracked where door latch pin is mounted...
Old Sep 20, 2009 | 03:06 AM
95POSmoneypit's Avatar
95POSmoneypit is on a distinguished road
Exclamation Body cracked where door latch pin is mounted...
I just bought a new rig and was looking at the door hardware to see what needs replaced for the door to fully close. I noticed there is a few large cracks in the metal behind the latch pin to the drivers door. (Apollogize if I am using the wrong terminology) I don't have any pics at the moment, but was wondering if anyone else has encountered this issue, and possibly what can I do to address this issue?
Old Sep 20, 2009 | 06:33 AM
AJBert's Avatar
Remove the door via the hinges, then cut the hinges off, weld up the cracks, reweld the hinges and hang your door.
That's the short version but really the only way to fix the problem.
Old Sep 20, 2009 | 10:00 AM
Well, I guess the plus side is it is on the other side, so all I have to pull off it the little latch point where the door closes... Still, ouch! Thanks for the reply!
Old Sep 20, 2009 | 10:47 AM
NVANZEE's Avatar
he is talking about where it latches not where it hinges. Thats is cause by bad pins and bushings. They have been ignored for too long and the weight of the door closing many times has caused the steel to tear. The way to fix it would be to remove the latch pin and get it welded up. Then put in a new latch along with the new pins and bushings.
Old Sep 20, 2009 | 11:34 AM
96chevblazer's Avatar
i close my doors gently cause i dont wanna do this in the future lol
Old Sep 20, 2009 | 04:51 PM
AJBert's Avatar
Oops! Guess I misread that just a bit.
Old Sep 21, 2009 | 02:17 AM
Thank you for the replys. Is the procedure to replace the pins and bushing pretty cumbersome, or require specialty tools? I remember reading in other threads that the kit is only about $20? Thanks guys, sounds like I am looking for a decent welder...
CTMark629
Nov 11, 2020 10:29 AM
ussexplorer
Aug 10, 2011 12:14 PM
budman802g
May 22, 2011 08:04 AM
portcqb
19
Jan 22, 2009 02:53 PM
djmurph
Jan 28, 2007 03:45 PM
