Door lock actuator replacement
Old Aug 19, 2018 | 05:55 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Default Door lock actuator replacement
After searching the forum to find out why my drivers side door lock will unlock but not lock I've learned it's the actuator. I've searched the forum and the internet to learn how it's replaced but so far I've failed to find any instructions on how to do it. I've looked at it but it's hidden in the door and I can't determine how it mounts. Does anyone have a link to a video or can you tell me the steps to replacing it? Any help would be greatly appreciated.
Old Aug 20, 2018 | 07:25 PM
Default Found this on a1auto.com
Old Aug 20, 2018 | 08:44 PM
G0LFADD1CT's Avatar
Thanks Don !!
Old Aug 29, 2018 | 03:56 PM
N. Jensen's Avatar
A1 is usually rather reliable.
The door is held on by a single phillips screw in the handle bezel, and 2 bolts (7 or 10mm..?) under the arm rest, then all the clips.
But I'm sure you've already figured that out.
Old Aug 29, 2018 | 05:52 PM
GreenBlazer2002's Avatar
Unfortunately the only part that you can truly rely on is that one Philips head screw. Everything else has probably failed by now.
Old Aug 29, 2018 | 07:52 PM
G0LFADD1CT's Avatar
I've had the door panel off to repair it and the broken armrest so that's no problem. I received my new drivers side mirror today so once I purchase the actuator I can kill two birds with one stone. I'm still a little confused by the description above that says rivets need to be drilled out. I've looked and I don't see any rivets. Hopefully I just missed them and I can figure it out.
Old Aug 30, 2018 | 12:27 AM
G0LFADD1CT's Avatar
I'm trying to buy the actuator online but I'm seeing two different ones listed. My Blazer has a key fob to unlock the doors. Which one is the one I need?
Attached Thumbnails Door lock actuator replacement-8146o-bfjel._ac_ul320_sr244-320_.jpg
Old Aug 30, 2018 | 11:35 AM
N. Jensen's Avatar
​​​​​​So much truth to this statement.
cochran07
Mar 11, 2011 03:33 PM
Murphy Mumgart
Jan 29, 2011 06:46 PM
dustinhxc
Jan 1, 2011 04:10 PM
Charger
Jan 4, 2009 08:40 PM
truck608
Oct 14, 2007 11:56 PM
