door post issue
i figured it out underneath were clips for the trim around the seatbelt shoulder harness, 1 big t50 torx and i just knocked em up with a hammer,, of course standing up the bottom crner of the door dug into my back but now it is done LOL
My driverside door was leaking. Coming in from the top of the door, especially in the car wash. The bushings in the door pins where wore out and not holding the door upright. Open the door all the way and lift up on it. See if the door wiggles up and down a bit without moving the whole truck. If the door wiggles the bushings are shot. Cheap fix. I changed out the pins and bushings in both front doors. Stopped the leak and stopped the doors from creaking terribly when I opened and closed them. If you find this to be a problem and decide to do it; bring a friend and a floor jack, you are going to want an extra set of hands. Make sure you get a door spring tool before you start, other wise you will never get the spring back in.
I had had a buddy replace the pins and bushings,,a few months ago, he said it was in need for so long the hole where the pin goes into got too wide, he welded it..the weatherstripping and some adhesive seems to have stopped the water for the front doors but the area by the lift gate looks like a night mare...it rusted right through by the hinge, I noticed this when I took off the trim piece at the top,, praying it was the third brake light gasket. With that trim off, there looks like a vacuum line??? Well it is disconnected, anyone know what it actually is? I need to talk to my buddy about a cheap fix for this hole : (
yes it is washer fluid line,, my cheap fix for the hole will be some aluminum can and rustoleum leak stop stuff 10 bucks ....the rear end however may be big decision time
btw thanks for all the very good information here
Last edited by Thogert; Aug 15, 2013 at 08:47 PM. Reason: Combining consecutive posts.
