door problem
Old Jan 26, 2013 | 06:51 AM
phatso_99blaz's Avatar
phatso_99blaz is on a distinguished road
Default door problem
New to blazers.. My drivers side door seems to not be sealing properly.. Door gaskets look good but allows water to get in and its loud going down the highway..any tips?
Old Jan 26, 2013 | 06:58 AM
coolasice's Avatar
coolasice will become famous soon enough
check you door pin bushings, with the door slightly open, grab it and pull up, if it moves your bushings/pins need replacing.
Old Jan 26, 2013 | 07:20 AM
Thanks.. I ran outside real quick to check..there is a little play and noticed door is leaning down a bit.. Can I get the bushings for that any parts store?
Old Jan 26, 2013 | 07:26 AM
coolasice's Avatar
yup, usually $5-7 per pin/bushing set... 2 per door
Old Jan 26, 2013 | 09:16 AM
Thanks for the help
Old Jan 27, 2013 | 05:53 PM
So I bought 2 from oriellys and put them in still have the problem...are all the bushings suppose to the same size? Because the kits they sold me have 2 different sizes. Top one fitting loosely..
Old Jan 27, 2013 | 08:22 PM
LeWhite's Avatar
It dosnt look like the bushings are the same size On my 01 the bottom pin nails down and the top pin hammers up. The bigger bushing is closer to the pins head. IMO Prolly check YOUR passenger door with a flashlight
Old Feb 27, 2013 | 04:20 PM
89 Blazer Lebanon's Avatar
89 Blazer Lebanon is on a distinguished road
Sometimes if you have bad body mounts or rust in their areas (mostly the ones under doors hinges), the cabin becomes kind of twisted and not well leveled, which causes doors misalignment.
Old Feb 27, 2013 | 05:15 PM
greencactus3's Avatar
greencactus3 is on a distinguished road
yes, different sizes, also, i found ebay was the cheapest source for buying a full set (2 doors)
Old Feb 27, 2013 | 08:18 PM
richphotos's Avatar
my body sags a bit cause of broken upper cab mounts, once i get them replaced, they will be back to normal.
teamrojas
Jan 21, 2013 12:30 PM
speedfiend
Jan 31, 2009 01:52 AM
MowJo
Aug 13, 2008 08:52 AM
GMdesigner
Oct 4, 2007 01:55 PM
dropd4door
Feb 10, 2006 02:34 PM
