Exterior Common Wear
Old Sep 18, 2008 | 08:03 PM
Flea323's Avatar
Flea323 is an unknown quantity at this point
Default Exterior Common Wear
Hey, hope everybody that reads this is doing ok. I know everyone has seen the rear window trim on the 98-05 Blazers deteriorate. What I was hoping to find out is if you could do something like the rhinoliner on the trim?. My roof rack is also starting to look very poor and I was hoping to do it also. Just hoping someone knows how well the Rhinoliner or its equivilent works. Thanks.
Old Sep 18, 2008 | 08:05 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Exterior Common Wear
mines doin the same the coating is chipping off i`m gonna take off as much as possible and spray paint it..
Old Sep 18, 2008 | 08:07 PM
NVANZEE's Avatar
i sanded mine down last fall and repainted it and by it is already bad again
Old Sep 19, 2008 | 06:45 AM
Flea323's Avatar
Hey, Thanks For The Replys, mine has really rotten away so i would have to bondo or something to build the surface back up. That is why I started thinking put something thick on there and try to form it the best I can. The Body Shop said it would be $600 to replace both windows cause you can't change just the trim. Thanks Again.
SmokedGhouda
Oct 8, 2013 01:17 PM
dve330
Apr 22, 2011 09:03 PM
nj4x4blaze
Shows & Clubs
Sep 23, 2008 10:27 AM
flyinbrad
Sep 28, 2007 02:21 PM
kngflp
Suspension Tech
Nov 11, 2006 06:55 PM
