fender flares?
Well, I want them to stick out a little bit but i'm not sure which one I'm looking for. This picture is a more up close shot of the fender flares.
that second pic sure looks like the factory 4X4 flare.
which looks pretty killer on that (slightly) lowered Blazer btw.
Ok, thanks now I'll just have to find out if the 4x4 fender flares will bolt up in same holes as the chrome ones.
Also, thanks that's in short along the lines of the same look I'm hoping to achieve with my blazer.
The black plastic flares on a first gen are the same on 2wd or 4x4. The fronts on a truck are the same for a suv but they are different on the rear. As for the bolt holes I doubt they will use the exact same holes but they both mount under the fender so you will never know. I've taken the chrome ones off and put the plastic ones on before and even taken one off to leave it bare. Unless you are under the fender looking up removing either is not noticeable. If you are under my fenders looking you have bigger problems than noticing the holes in my fender lips.
thanks for the info, I think the ones I'm looking for are the 4x4 ones I'll have to see if I can pick some up from one of my local salvage yards.
