Fitting
RE: Fitting
Negative.
You need a brush guard that specifically says for ZR2 blazers.
RE: Fitting
I have been looking around every were and I just cant seem to find anything that will my ZR2
there was that Warn 38475 Trans4mer Grille Guard but it says it only fits up to 02 vehicles...
"The Trans4mer grille guard is essential to have as the foundation of the Trans4mer system. It bolts directly to your vehicle's frame and is a base for all other options. It comes in a black finish with two uprights and two crossbars. Compatible with the following Chevrolet models: 98-02 S10 Blazer; 98-04 S10 Pickup. ZR2 models only."
RE: Fitting
bah nvm there no way that one will fit...
I'm thinking I might just half to have one fabricated sense no one sells them for my vehicle
RE: Fitting
is there a big difference between 02 and 03 zr2's?
if there isnt, i would go ahead and get it
thats the only bad thing about zr2's
aftermarket parts are not too common
i will keep my eye out for one
RE: Fitting
well werent they suppose to come with one? I thought I heard some were on these forums that they did
RE: Fitting
No they didnt come with them, they were optioned. Manik is the manufacturer of the stock guards. But Warn Transformers fit, Westin Sportsmen, and Maniks all should be available for 98+ ZR2s.
RE: Fitting
Sweet
So this will fit it then then? I am also worried about the skid plates getting in the way and maybe some vibrations at high speed...
RE: Fitting
No that one wont fit..you need one that specifically says for ZR2 blazers.
The mounts dont really affect your skid plates, and if its made for your truck, the mounts will keep it from moving even at high speeds.
