Frontend change
Old Mar 13, 2010 | 01:23 PM
cyberdog's Avatar
cyberdog is on a distinguished road
Default Frontend change
I have a 1996 Blazer and it has really bad / small front lights. What do i need to change if i want to put on 97 or newer lights ?
What years did the lights in the front change ?
Old Mar 13, 2010 | 01:42 PM
Benedict1337's Avatar
1998 they changed. you looking to change it to my front end right? I'm pretty sure they make a kit for it but you'll need the headlights, bumper lights, grill, bumper and new radiator mounts. I'm not 100% sure if the actual light bulb sizes are different or not. in the end you are probably looking at spending at least $200 depending on if you get the parts new or used.
Old Mar 13, 2010 | 02:00 PM
cbr995's Avatar
Just do a search, bro. This has been discussed many times.
Old Mar 13, 2010 | 03:40 PM
cyberdog's Avatar
Did search but couldt find what i was looking for
1996 had the small front lights, when did they change to bigger ones and when did they change to the ones with 2 in the front ?
Old Mar 13, 2010 | 05:35 PM
cbr995's Avatar
The Composite lights were an option on the 4 door since 1995. You have the sealed beam lights.
The front end like mine(shown in sig) came out in 1998.
Old Mar 14, 2010 | 03:43 AM
cyberdog's Avatar
Oh ok.
The 1998 front is the one i was thinking of. Are there kits to buy to convert to that front or ? Also what parts do i need to change ?
Old Mar 14, 2010 | 07:06 AM
MrTwister's Avatar
MrTwister is on a distinguished road
Old Mar 14, 2010 | 01:07 PM
oktain's Avatar
You'll need to change:
obvious stuff
-grille
-headlights
-signal lights
-bumper
-valence (plastic part under bumper)
-all the fasteners
not so obvious stuff
-rad core support
-bumper brackets (IIRC)
You have to be careful because your Core support can either be bolted on (like my 05) or be welded in, which then becomes a real PITA
I suggest you look here:
http://chevroletforum.com/forum/showthread.php?t=14500
Old Mar 30, 2010 | 02:52 PM
JeremyNYR's Avatar
JeremyNYR is on a distinguished road
[quote=oktain;311980
[/quote]
I've seen this in a few threads on this topic now. What is the split between Blazers that have a welded in and bolted in support? Was it split by model years? Assembly plant?
Old Mar 30, 2010 | 07:19 PM
oktain's Avatar
No clue... I found that in my research and no year span was found... it could be "plant" dependent too...
