Grill Guard Mounts
Picked up a Factory Girll Guard that mounts where the tow hooks go
Only thing is it did not come with the mounting brackets. Anyone know where I can get a set or have drawings that I could make some from? |
2 Attachment(s)
What year is ur Blazer ?
Pic of the grill guard u got ? (if possible have a buddy hold it in same position as mine to compare) These brackets are quite simple and mount using existing bolts, but.......... if ur planing to winch off it, got to go another bracket way for sure. https://blazerforum.com/forum/attach...ine=1467366118 |
6 Attachment(s)
Hey thanks for the quick reply
No plans for a winch maybe some lights I have a 2000 Blazer ZR2 I test fitted it and it looks like it will go right where the tow hooks are and below the grill Attached are a couple pictures |
Originally Posted by MustardTiger1337
(Post 666577)
No plans for a winch maybe some lights I have a 2000 Blazer ZR2 I test fitted it and it looks like it will go right where the tow hooks are and below the grill Attached are a couple pictures recovery hooks or not. Is there a name brand or any numbers on your guard to help identify the guard maker/model ? (This would be a bonus..Lol) Been a while since I had to mock up brackets, but you can use some thin sheet metal that you can cut and bend by hand... (or at least thats how I did it many moons ago..Lol) |
Was told they came straight from GM
There is a sticker with 31941 D No other markings No issue if I loose my hooks |
(Post 666582)
There is a sticker with 31941 D No other markings No issue if I loose my hooks Did they say what it came off exactly ? Im curious where the brackets angled inward are going ? Maybe someone on here has the exact setup that can help with the mystery ...Lol Call your chevy dealer give them that number or see if they find a oem grill guard for your yr / model I can only find oem factory brush guards for the following Avalanche / 1500 truck / Hummer Cant tell ...is the bottom bar a step ? If so it may be a old GoRhino product number the new one is 3140B, it has close match end bracket as yours, you could contact GoRhino, see if that was a older product number....... I will keep sniffin around the web, but nothing comes up on 31941 D and not a GM Number I found. (I also tried GMPartsdirect ) |
I was told it came off a 2000 Jimmy and was bought Directly from the dealer GM
Long weekend right now but I will give them a call next week In the past they have not been very helpful with anything older then a couple years the middle brackets look to mount right above the bumper. Grill has to be removed to get at the bolts I look around pretty good before and after I bought them and came up empty as well. The price was too good to pass up so I figured I would take my chances |
4 Attachment(s)
I have found two online that look similar
but not much else |
(Post 666585)
but not much else The two you found did they have any owner links ? |
2 Attachment(s)
UPDATE
Found some Figure I would post them just incase anyone else has the same issue. Confirmed they are stock from GM Tow hooks have to be removed |
| All times are GMT -5. The time now is 07:29 AM. |
