Halo Projectors
Old Dec 20, 2005 | 09:20 PM
LittleDan911's Avatar
LittleDan911 is an unknown quantity at this point
Default Halo Projectors
I'm Wondering If Theres Anything I Should Worry About Running Into Installing These.... http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
Old Dec 22, 2005 | 06:00 PM
Default RE: Halo Projectors
Still Wondering If Anyone Has Ran Into Any Probs
Old Dec 22, 2005 | 10:20 PM
Common problems with pretty much any aftermarket headlamp like that is poor sealing. Many of them have inadequate sealing between the clear front lense and the rear section, typically just **** poor friction welding. If you do go with these, try to thoroughly clean this area on the outside of the headlamps and then take a good silicone based sealant that hardens up (RTV will do) and get a good coat over this area to minimize the risk of moisture buildup in the headlamps.
Other than that, the look pretty sweet. If no one else has tried them, the you really don't know what the beam pattern is going to be like, not to mention if they are even DOT approved, which may fail you on an inspection depending on the restrictions in your state/area.
Old Dec 23, 2005 | 03:19 PM
Ty For The Tips , There Dot Approved I Made Sure First..LOL Same W/My Tail Lights Thats One Thing I Look For
Old Jan 1, 2006 | 04:34 PM
enrybwerd's Avatar
enrybwerd is an unknown quantity at this point
i wanna see a pic of what it looks like on ur blazer.. im thinking about getting some halos for mine and i wanna see what they look like. thanks
Old Jan 1, 2006 | 06:14 PM
Will Do So, I Was Shocked When It Only Took Me 15 mins To Install But They Look Sweet
Old Jan 9, 2006 | 12:09 AM
ric6312's Avatar
ric6312 is an unknown quantity at this point
put a set like these in my sons s10,,look good and no problems,,look real good with just parking lights on..mine are called angle eyes,,
Old Jan 22, 2006 | 10:52 AM
85FSBSilverado's Avatar
85FSBSilverado is an unknown quantity at this point
DOT approved, but doesn't mean you'll get a bad batch, or the quality didn't go down afterward. Never had problems with aftermarket corners in the Cougar, but had others have problems from the same company. Just depends on the particular ones you get. I say go for it. I've always loved those. Friend has them on his Explorer. They look sweet at night.
Amart88
Jan 25, 2013 09:56 AM
Blazer51
Dec 23, 2011 10:05 PM
odfareal
Aug 21, 2009 02:31 PM
WhiteTie BlackJacket
Aug 2, 2007 04:41 PM
TheDesertFox
Oct 3, 2006 06:24 PM
