Headlights
Old May 14, 2006 | 11:21 PM
quick28573's Avatar
quick28573 is an unknown quantity at this point
Default Headlights
I have a 1997 blazer with the sealed beam headlights I am wondering if I can use these headlights.
http://cgi.ebay.com/ebaymotors/ws/eB...3438%26fvi%3D1
I am new to this modifications thing so any help will be greatly appreciated.
Old May 14, 2006 | 11:59 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: Headlights
if that looks like urs then it should as the years are the same. then I'd say yes.
Old May 15, 2006 | 12:06 AM
quick28573's Avatar
i have the two piece lights where the headlights are square and the corner lights are seperate
Old May 15, 2006 | 12:50 AM
XBlazer01's Avatar
hmmm Try and find the ones that are split up. Lol sorry bout that!
Old May 17, 2006 | 11:18 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
if you have the sealed beam headlights like i do, then no you cant use them
kind of funny, i almost bid on these on ebay, actually sent you a message if youre the seller.
are you still trying to sell these? I'm interested in buying them for a composite headlight swap
Old May 18, 2006 | 02:12 AM
BLZNHOT97's Avatar
BLZNHOT97 is an unknown quantity at this point
hi, welcome. Im new to this forum and mod thing too! i also have a 97 blazer w/composite headlights and yes those are correct lights for the truck. im actually looking to buy the same type of headlights aswell-they ll look great on. just make sure they say they are for composite headlights only. Good luck
Old Jun 2, 2006 | 02:51 AM
djremix's Avatar
djremix is an unknown quantity at this point
I have these composite headlights for my Blazer and they do look awesome. If you have the sealed beam headlights, technically YES you could use them, assuming that the radiator support is the same BUT...BUT you'd have to modify the wiring because you'd now have 2 bulbs (low and high beams separate) and you'd also have to replace your grille because the grille is completely different. If someone can convert a 95-97 to a 1998 and up, it shouldn't be very hard to convert your sealed beams to composites...Good Luck!
hollywoodgrad
Jan 25, 2012 01:58 PM
AzBlazer
Jul 3, 2005 04:17 PM
FatRyan
Mar 8, 2005 03:27 AM
BlazerSquad93
Feb 17, 2005 11:52 PM
jaleg
Nov 17, 2004 02:53 PM
