which hood?
Old Mar 26, 2007 | 03:50 PM
Blazer_Xtreme's Avatar
Blazer_Xtreme is an unknown quantity at this point
Default which hood?
Im looking into buying a aftermarket hood for my truck an I was wonderin if I should go with either the steel or the fiberglass and what are the pros and cons of each. Thanks alot
Old Mar 26, 2007 | 04:53 PM
TripleBlackBlazer's Avatar
Default RE: which hood?
I've only done a little bit of research but here's what I know.
Steel:
Pros- 99% of the time it's a direct bolt-on. Superior quality. Longetivy. Won't crack or tear. Can use stock hardware.
Cons- Cost. Weight. Higher shipping due to weight.
Links I have found for steel hoods:
4" cowl lift off - http://www.eharwood.com/catalog/prod...?productID=386
2.5" cowl bolt-on - http://www.eharwood.com/catalog/prod...?productID=426
4" cowl bolt-on - http://www.eharwood.com/catalog/prod...?productID=427
Fiberglass:
Pros - Lightweight. Price-significantly cheaper than steel in most cases. Wider variety of shapes IMO. (I've really only seen cowl hoods in steel). More availabilty IMO (ebay and such).
Cons - Usually not a direct bolt-on and require some shaping/sanding/filling. Easier to crack/tear than steel. Have to buy different hood latch and springs for some since stock springs are too strong. Fiberglass flexes more than steel. I guess this is for both but it seems you have to be sure of the seller a little more frequently with fiberglass than you do with steel.
Links I have found for fiberglass hoods:
http://www.extremecomposites.com/chevy.html (I'm also fiddling with the idea of their Corvette tailgate but it just seems too crowded)
http://www.teamxenon.com/mm5/merchan...de=CHEVY_TRK_6
http://up22.com/S10.htm#GM804
I can't tell if this is steel or fiberglass but the price would suggest that it's 'glass:
http://www.truckn-store.com/product....p&ID=93255
Hope this helps!
(Can ya tell I want a hood too? I'm most likely gonna go with the 4" steel cowl bolt-on when the cash comes in)
Old Mar 26, 2007 | 10:39 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Get ahold of Goodmark Industries....1-piece steel...is the only way to go IMO.
Old Mar 27, 2007 | 03:58 PM
Thanks ALOT guys I knew I could count on this forum forsomr help.
Old Mar 27, 2007 | 10:06 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
I like this one: http://www.truckn-store.com/productI...HOO-CV8293.JPG
or those SS Camaro style fiberglass hoods. I think I'm gonna go with the SS for my truck.
Old Mar 27, 2007 | 10:08 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Definitely go steel. Fiberglass tends to crack where steel would just bend.
I'm partial to this hood:
Old Mar 27, 2007 | 10:12 PM
Isn't that the SS Camaro style? Is that steel or fiberglass? I have only seen them in fiberglass.
Old Mar 27, 2007 | 10:21 PM
lastcoupe's Avatar
I think that is a Goodmark STEEL "ram-air" style hood hereis a link.
Old Mar 27, 2007 | 10:24 PM
That looks like the one, but I guess the one I was looking at was different. It was called an SS style and it was fiberglass. I like the fact that this one is steel though, so I may be going with it instead....
Old Mar 27, 2007 | 10:29 PM
Jigg's Avatar
Yeah, it's a goodmark Gen III steel hood. Just put it on this weekend.
