how do u replace sunroof seal???
Old Oct 4, 2009 | 02:13 PM
multitrack24's Avatar
multitrack24 is on a distinguished road
Default how do u replace sunroof seal???
does anyone know how hard it is to replace the sunroof seal for a 2004 Chevy Blazer ZR2. 2 door.
Thanks
multitrack24@hotmail.com
Old Oct 4, 2009 | 03:16 PM
The first trick would be finding a new seal.
The glass just unbolts. There are four bolts holding the glass in one at each corner pointing from the inside area of the glass towards the sides of the truck.
What is going on that makes you think you need a new seal?
Old Oct 4, 2009 | 03:40 PM
I finally saw a few drips of water getting thru while it was raining. I hope a new weather seal will work. Thank you very much for the reply, please let me know if you have any other tips. Thanks, Matt
Old Oct 4, 2009 | 04:00 PM
There is a drip rail around the outer portion of the roof. Any water that gets past the glass is supposed to drip into this area. There are 4 drains, one at each corner. If you are getting water into the truck, your drains are likely clogged and it may not be caused by a bad seal.
Old Oct 4, 2009 | 04:38 PM
I can see the two toward the front but am unable to locate the two rears. Is there any way to find them and unclog?
Old Oct 4, 2009 | 05:56 PM
You may have to put the sunroof in the vent position to access the rear screws.
As far as the drains go, the front drains can be accessed when the sunroof is all the way open. I cannot remember if the rear drains can be seen when the roof is open, in vent, or only when the glass is removed.
Before you remove the screws, you may want to scribe their location. The glass is adjustable up and down for proper alignment with the roof. Too high and it will bind. Too low and more water may leak past than intended.
Thermm
Oct 8, 2012 08:15 PM
litterbug
Mar 7, 2011 09:14 PM
kevin turner
Apr 9, 2010 01:21 PM
GLBL WMR
Nov 14, 2009 05:54 PM
stevelknievel
Aug 11, 2007 03:22 PM
