Led
I bought two blue LED lights. I want to put them in the front floor under the dash in my 96 blazer. They plug into the cigg lighter. Is there anyway i can run them so they turn on and off with the ignition? And what would be the easiest way to do it?
on the driver side of the dashboard there is a fuse panel, pull the access door and unbolt the fuse panel, then with a test light or multimeter test for 12v with the KOER and 0v KOEO, then splice into that wire and run your wires under the dash. try to pick a circut with a high amp rated fuse like 15A or 20A
96jimmyslt4x4
Sep 21, 2011 09:14 AM
96jimmyslt4x4
May 29, 2011 03:55 PM
