LED Flasher
Old Nov 9, 2007 | 12:18 PM
Cooligan's Avatar
Cooligan is an unknown quantity at this point
Default LED Flasher
Wanting to convert the exterior lights to LEDs. I have a '00 Grand Prix GTP that I have compelety coverted to LED's and was able to find a flasher for it to fix the hyperflash issue. What I need now is a heavy duty/LED flasher for the Blazer. I guess another question is where is the flasher module located on a 99 2dr blazer and also if anyone has info on where a LED flasher can be bought from. Thanks.
Old Nov 10, 2007 | 02:08 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: LED Flasher
Most flashers will be in the passenger side dash. Depending on the model, your glove compartment should open like this:
ORIGINAL: Eurogoldls
Thread: https://blazerforum.com/m_78530/tm.htm
Just push the metal clip up:
and the glove box will completely fold out:
If you look in the bottom right of the space behind the glove compartment, you should see a bunch of small wires, The signal flasher is to the right of them.
As to where to get the flasher from, autozone, pep boys etc. should have plenty of them.
Old Nov 10, 2007 | 03:36 PM
Cooligan's Avatar
Thanks for the info, greatly appreciated.
Old Nov 10, 2007 | 04:32 PM
EuroGoldLS's Avatar
You're welcome. I didn't mind in the slightest!
Old Nov 10, 2007 | 06:25 PM
Cooligan's Avatar
I went out to the truck shortly afterwards and found it. Wasn't sure how to get the green retainer strap off so I moved it off to the side without actually detaching it. Seemed to work.
Old Nov 11, 2007 | 05:46 PM
EuroGoldLS's Avatar
yeah thats what i did when I changed the one on the Sonoma.
Old Nov 12, 2007 | 10:58 AM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
ORIGINAL: EuroGoldLS
Yes, but please note that if your truck is older than '98, then the flashers are located under the dash, just below the radio and to the left of the cigarette lighter -- not in the glove box. I know this doesn't apply to you, but this is for anybody who reads this who has an older truck.
Old Nov 12, 2007 | 11:44 AM
EuroGoldLS's Avatar
Yes good side note.
96jimmyslt4x4
Sep 21, 2011 09:14 AM
96jimmyslt4x4
May 29, 2011 03:55 PM
apekim
Sep 15, 2007 10:46 AM
syrblitz19
Jun 10, 2006 02:27 AM
kccapt
Nov 23, 2005 01:34 AM
