LED Taillights
Sorry about teh bad link try this one. (towards the bottom of the page. Above the resistors)
http://www.superbrightleds.com/cgi-b...rn.html#Table4
and yes they are both relays but that is supposed to fix the problem also.
straight from superbrightleds web page:
Electronic LED Flashers
Many types of LED compatible car and universal motorcycle flashers
You should definitely use one of these instead of Load Resistors if we have one to fit your vehicle. They operate at the correct flash rate with LED or standard filament bulbs
10~15 Volts DC - Flash Rate: 80 per minute
Me too. I looked everywhere for those kind before I bought mine. I can't believe no one made them for ours. They even made them for the 1st Gen Blazers but not ours.
Ok cool, has anyone else put LEDs in the Front Corner lights? If you have, did you have problems with the arrows in your cluster staying on, as in being lit solid all the time.
RangerG the tail lights you have, there are two bulbs in that top "bubble" right? and the bottom circle is just a reflector? how do they look lit up?
Do you think you could put one of your LEDs from your tails in one of the corners up front to see if you had the same problem as me? That would be great. Maybe the LED flasher from superbrightleds will fix that too.
Thanks guys so far for all your help and info.
This happened to me when on of my front signal bulbs fell out of the socket.
Thats what i tired and it didnt fix it.
This is the EXACT one i bought: http://www.autozone.com/autozone/cat...questid=765757
