lights?
Old Jan 22, 2007 | 07:52 PM
blazinjimmy94's Avatar
blazinjimmy94 is an unknown quantity at this point
Default lights?
Does anyone no where i can find HID conversion kits for a 94 jimmy? websites? stores? anything? thanx
Old Jan 22, 2007 | 10:48 PM
blazer123456789's Avatar
blazer123456789 is an unknown quantity at this point
Default RE: lights?
try ebay to start
Old Jan 23, 2007 | 02:56 AM
BLK85's Avatar
BLK85 is an unknown quantity at this point
Default RE: lights?
www.ledgauges.com has a kit that Im going to buy herer pretty soon. They go right in the stock housing.
Old Jan 23, 2007 | 12:40 PM
Default RE: lights?
would the 93-to 97 trans am headlights fit my 94 jimmy, they look the same?
Old Jan 24, 2007 | 03:49 AM
Mapoftazifosho's Avatar
Mapoftazifosho is an unknown quantity at this point
Default RE: lights?
seriously...research.
Those lights probably will not work, but feel free to blow your money trying.
I do not believe that there are any HID kits for the
Old Jan 24, 2007 | 09:19 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default RE: lights?
Be Careful, not only are the HID's illegal(unless equipped from the factory) but if its not installed correctly Im sure a nasty fire will follow. Also, wire them up to your brights instead, easy way to escape a ticket.
Old Jan 24, 2007 | 04:36 PM
Default RE: lights?
To stay as 'legal' as possible. Get the OEM temp range with is 4300k to 5000k. Also aim them low and if you are running them in a stock reflector housing be certain to get D2R bulbs.
Old Jan 24, 2007 | 05:52 PM
drperry's Avatar
Default RE: lights?
ORIGINAL: DetroitMuscle
HID's don't work quite as well when wired to the highbeams, except for bi-xenon setups.
They don't like being turned on and off rapidly...
ORIGINAL: Mapoftazifosho
It's not so much the D2R, but the angle of the filament itself, is why HID's don't work so great without the proper projector setup... even with the D2R's you're still going to have some glare issues...
The filaments run like this:
Single filament: -
Double filament: =
HID: |
edavison
Dec 20, 2010 09:55 PM
cjs030901
Jun 7, 2007 08:51 AM
ewingmh
May 13, 2007 07:21 AM
98BlackBlazer
Aug 28, 2006 01:31 AM
rryker
Apr 25, 2006 04:14 PM
